Glad to Be here
Houlie
20
Worcester, Massachusetts
Hello all, Houlie here from Worcester, MA. I own an 87 Monte SS. I recently had a shop locally here, install a new ZZ4 350 crate motor, with TunePort injection. Hope to get pics of all the work I had done. Anyone w/ questions ofr thinking of doing, I will be glad to try to answer and offer advice. Lord knows once you get into it, there is ALOT more you can do
Thanxs
Houlie
Welcome to the site.
I put the TPI set up in my car too and I love it. I'm in the process of rewiring it though.
Definately get some pics up.
TPI wiring
The shop that did mine used the wiring set-up from Howel (or Howle). He said stay away fromt he Painless or "painfull" as he called it. The one from Howel comes with everything labeled, and wired. If you tell them exactly what your running they will set it up for it, ie Air. Just had some extra cash so I decided to stiffen up the rear suspension with the set-up from Edelbrock, lower and upper control arms, the upper are adjustable. Saved $250-$300 over the Hotchkiss set-up. Can't wait till spring thaw, gotta break in the new motor, then get it off to a local Dyno shop to see really what I'm putting to the wheels... I got a brother in-law with a 2002 Cobra, bragging about his 283hp
