smokes468 said:Had a good time & nothing broke 😀 , Car ran good & for the most part it hooked decent feathering it, I got no tire spin on 2 runs, the other 2 it spun & i let out to get it to re-hook, I had fun, car felt great, started out with 28 lbs. air, dropped it down to 24 lbs., changed jetting a bit on my last run, didn't help MPH at all, On my second run i pulled the air cleaner, same thing, no change, overall it was fairly consistent based on the 60fts. I was pretty easy on it through the 60ft. on all runs, then layed into it after that. The MPH was very consistent, shifted around 55-5600. There using a different prep & man is it working, cars were hooking hard, i'm sure thats why i didn't fry the tires off leaving the line.
1st. pass, 2.0x 60ft., 8.3 @ 86+ 12.7x @ 108+ change
2nd. pass, 2.2x 60ft., 8.5 @ 86+ 12.9x @ 108+ pulled cleaner & spun
3rd. pass, 2.0x 60ft., 8.3 @ 86+ 12.7x @ 108+
4th. pass, 2.3x 60ft., 8.6 @ 86+ 13.03 @ 108+ jetted up front from 72 too 75 & spun
GhettoRacingKid said:I know we all keep on saying get tires. But get tires.
U were definitely spinning. And the fact you arent full power gettin out of the hole is killing you
I think youll get a 1.7 60'.
When r u going back?
GhettoRacingKid said:Yeah youll be fine. Ive seen stock shafts on 7 second cars. Thats 1/4 btw
smokes468 said:GhettoRacingKid said:Yeah youll be fine. Ive seen stock shafts on 7 second cars. Thats 1/4 btw
Thats good to here, thanks.
