gp wont start(an its pi**in me off)
My Malibu wagon made that ticking noise too. Only when it was moving, and it was only noticible at very low speeds.
I was always too lazy to look into it, since it never created a problem, and the car ran/functioned just fine.
As far as the driveshaft thing goes,
You've got a 700-R4...
A good friend of mine had a '93 Caprice with a 700. It was towed for about 4 miles, and the trans went out a week later.
Since it's only four bolts to remove the driveshaft, I would recommend in the future to always pull it when towing, and then plug the tailshaft with either one of those plastic plugs, or an extra slip yoke if you have one laying around... unless you're fortunate enough to own/have access to a trailer.
It's probably fine, I just hope you have better luck than he did.
it doesnt chnge direction really its like its in the middle but at the same time all over...
an no i dont have a 700 i have a 200r4...an did u ever figure out wat that tickn noise was...
oh yeah is the flex plate the same as the flywheel
Saw the 700-R4 in you signature. Regardless, the principle still applies.
A flexplate is what auto trans equiped cars have, flywheels are for manual trans cars. Same concept, different parts.
oh ok so the flex plate is wat sit between the transmission and the motor.. basically ur startr turns ur flexplate on a auto trans
