I'm starting to think the "Special" coupes of those two years used them.And similar year Cutlass as well.
Since you've fabbed up plenty of things on your car, this would be no sweat, most likely. TBH, I've never seen how your existing torsion bar brackets are attached whether spotwelded or partially stamped in there, etc., but most likely spot welded. You could remove that and install a set of lift cylinders without much issue at this juncture. My only concern with that is...eventually at least one or both cylinders will give up the ghost, and it looks like it might be somewhat of a PITA to change. But what do I know. I'm keeping my torsion bar setups because they'll NEVER wear out.Wonder if I can retro a set on my 87?? Hmmmmm
Hutch
