You can always use a billet tensioner from Katech, Comp, etc. Once the belt breaks in I don't think you'll really see that much change, if that was the case I'd be having to adjust my Katech tensioner all the time
I have an Iceman crossmember and I'm extremely happy with it. The BRP mounts that I have don't use the original V8 mount holes, so technically it keeps the trans in the same spot just as it would with other mounts.
If you have any junkyards around you, try and look for an alternator from a truck with a 4.8/5.3/6.0, as it's the same casing alternator just without the stupid cooling duct on the back. I'd be willing to bet if you got a truck alternator on there you wouldn't have too many issues with the spark plug or coolant sensor.
I also wouldn't worry too much about the distance from the crank to the next pulley.
