Gravity Bleeding Brakes
I bought one of these last year, It's very handy.
Works pretty good for flushing or bleeding the brakes or clutch master cylinders.
I've been gravity bleeding brakes for years, here's how I do it;
Get the car in the air with the wheels off.
Take the cover off the M/C.
Open a bleed screw and let fluid run out until clean fluid comes out, keep topping up to make sure the M/C doesn't run too low.
Repeat on the other 3 wheels.
Top up the M/C and replace the cover.
Check to see if I have a good pedal.
Refit wheels and road test.
Roger.
Whenever I do a big service like raplaceing calipers or lines I always gravity bleed. I do one wheel at a time and It sure cuts down on bleeding later on.
Im always alone when it comes to bleeding brakes and the best way I do it without having to buy any equipment is. I take a cup and fill it about 1/2 way up. Then I take a piece of vacuum like and put it on the nipple of the bleeder and submerge the other end in the cut with brake fluid. I crack the bleeder and pump the brake. Instead of sucking air, it sucks in more fluid . Keep an eye on your resevoir level. Repeat for all wheels....Works everytime for me and it only cost the amount of a Red solo cup.
I gravity bleed the brakes so I have time to have a couple of beer, then I bleed them with the speed bleeders I have installed. I start from the furtherest away from the master and work my way in..
