H-4 Headlight problem...
I just tested the green wire and there is power there.
I will have a look at the relays next.
Guy
make sure you have the brown wire going to the low beam and the green going to the high beam..The halogen bulb is different than a sealed beam
Since they are on relays it should not be overloading the breaker. Maybe get an assistant to work the dimmer switch while you listen/feel for the high beam relay to work as a place to start. You will likely have to chase the problem down with a multi-meter. It's most likely a crossed wire, bad connection or maybe a bad relay. Maybe try swapping the two relays to see if that changes anything as a quick test.
Well it turns out it was a bad connection at one of the relays.
As soon as I removed the relays I could see there was a loose wire.
I put that where it is supposed to be,hooked the battery back up and now all my lights are working properly.
Thanks for the help fella's,it is appreciated.
Guy
