I'm surprised holley discontinued them, seems like alot of R/D to waste, i thought everything else in the gbody kit was designed to fit around the headers.
The speed engineering LT headers fit with minor modifications and seem to be high quality. Hard to beat stainless LTs for 400 bucks.
That's basically your only option, except fbody pacesetter headers(which also require similar mods).
The driver side lower control arm mount needs trimmed up, and the pass side frame rail needs some cut out.
I used ict swap plates. I almost think the spohn/fbody mount setup would clear the passenger side without modifications but im not sure.
If you buy them I'd do the passenger side modification when u pull the old engine out. I clearanced about 3/4"-1" out of the top and beat the sides in. Then I clearanced the driver when everything was installed.
Upon further review, I don't see headers on holleys website but I found these.
Put the power down and pump the sound up on your hot rod with a Hooker exhaust system. We have performance headers, manifolds, slip-in mufflers and more.
www.eastwood.com
Get the Best Performance with Hooker Headers HDRS G-BODY LS 70101505-1 parts at JEGS. Shop Now at the Guaranteed Lowest Price!
www.jegs.com
And also this if you wanna buy holley....
