Headlight switch wiring
twinal1014
n00b
Nov 16, 2021
Can anyone help with a diagram for a headlight switch for a 86 Buick Regal limited. I am in the process of putting in a new wiring kit. And need help connecting new wiring into headlight switch. Any help is appreciated.
Tobtech
n00b
Dec 5, 2021
2
I'm rewiring a '87 Regal and need this as well. I wouldn't mind having a whole wiring diagram. I'm using a universal harness with headlight relays. I attempted to test the switch but it appears to be bad but I would like to start with a wiring a diagram to confirm. If I find something first I will share it here.
ELCAM
1,124
1,270
Been looking through many wiring diagrams and those colors do not match anything I see. Biggest problem is GM used a yellow wire for the headlights, goes to the dimmer/Hi-Lo switch. Only two make sense in GM colors the grey would go to the dash lights and orange is often a power feed color (There are other uses for orange wires but they are never 12ga wires).
Did that wiring pigtail come from your regal? This same switch is used on other GM models, also this same switch with different markings that represent the same functions on the buttons is used in some Jeeps.
