Headliner question
69hurstolds
8,198
17,600
I've always used 3M Super 77 or 90.
They might work but I'd use 3M 38808 specifically designed for headliner and fabric gluing jobs. Around 15 bucks per can or so. Works extremely well.
69hurstolds
8,198
17,600
Awesome these are great tips, I have some questions though! You refer to the interior code, I assume my color is the dark claret as you mentioned because from any pictures I've seen its what looks the closest to what I have BUT all of my interior codes refer to it as Ruby red but I can't seem to find anyone who has that color. Could they be one in the same?
Sent from my Z978 using Tapatalk
Well, Oldsmobile used Dark Claret for code 79C. Yours may be called something else. Same color.
What year is your car? You can check the SPID sticker in the trunklid if it's 84-88. assuming it's still there it should list all your option codes. If it's 85-88, it's 79C I'm betting. I think Chevy called this the Ruby Red, but not 100% sure on that. If it's code 77C it's pre-85 and would likely match the Dark Maple.
Sorry, I'm not quite fluent in Monte Carlo specific stuff. I speak Oldsmobile language mostly. :)
lp08ss
32
9
8
My car is a 1988 and the sticker is still there on the trunk lid, I don't see a 79C though. I think mine is 79T but I'm assuming that's it because all the other 79 codes are things like trim color, seat belt color etc but I can't find a description for 79T. And no worries your current language seems to be helping out just fine! Hahah
69hurstolds
8,198
17,600
First two numbers are the important piece. 79 interior code is Dk Claret/Ruby Red. The letters are colors for certain components of the interior or trim or striping. If the last one is a number, like 794, I think that signifies leather colors. Your 79T should indicate ruby red vinyl top color. Does yours have a red top? Letters like N, R, V and such indicate vinyl. I haven't memorized them all.
It can get confusing real fast.
pagrunt
9,168
15,348
Elderton, Pa
Here is how to understand the 00X for intierior codes. (From my parts bible)
Combination Number Coding: Thefirst two numbers indicate the basic color, i.e. 19=black. The third number of letter indicates the typeand design level as follows:
Cloth & vinyl: B-C-D-E-G-H-J
Vinyl: N-R-V-W-Y-Z
565bbchevy
9,614
12,683
Michigan
Regardless of where you get your headliner material from I would suggest getting some material samples just to verify a match, for me I was trying to match a new factory interior from an unknown Gbody so codes did not apply but I got 4 samples and one was a perfect match.
lp08ss
32
9
8
Exactly I do indeed have the vinyl top!
lp08ss
32
9
8
Thank you guys so much for the schooling it all makes sense! I'm a young guy so I'm unfamiliar with some of this older stuff lol
69hurstolds
8,198
17,600
If you have never done this job before and want to tackle it, seek help from someone nearby you that's done this sort of thing before. It's not real difficult, but if you haven't learned the ropes, you may get in over your head real fast. I'm not trying to discourage you, but there's a bit of finesse and learning curve you have to do with these stupid G-body headliners. The headliner was put in the car when the windshield was yet to be put in. Made it real easy. You can pull it out the passenger side but you may have to remove the passenger seat or recline it if you're lucky enough to have recliners. Bench you may need to remove the entire seat, not sure. I removed the non-reclining bucket on the passenger side of my 87 442 when I did that headliner.
