Hi all, I'm going try and reglue headliner cloth back up. Do I need to remove foam and replace it, or remove it and glue cloth straight to board. Headline is around 8 to 9 years old. Thanks
What you're going to encounter depends, in part, on what is there for a backing board and what material was used.
If you have the factory backing board, and if the maerial used was a factory style foam backed fabric, then you would want to do the following (assuming hardtop car, astroroof and ttops differ slghtly):
First remove the board and set on a table. Front and rear metal trim plates screw to the roof, sides remove by gentle pulling towards the interior of the car to release clips before removing downwards. Make sure to pull the fuse for your dome light before removing lens and the two slip on fasteners securing the lamp to the mount, there is a risk of shorting something based on metal contact. I use needle nose pliers to remove the fasteners.
With the board out on a flat surface pull the fabric off. You will need to remove the residual foam attached to the backing board as this is what causes the sag - it's the bond with the foam breaking down and separating from the fabric, not a glue wearing off the backing issue. If you don't get the foam off, your new covering won't hold as long.
Typically rubbing the foam residue with your hand will cause pills and remove the majority of the foam. Lint rollers can get the rest.
I always repair factory backing boards, and fix cracks and issues by coating with fiberglass resin, couple coats and you're good. Inconsistencies I fix with glazing and spot putty, than after drying/curing a light coat of resin. Makes a good stiff secure surface for gluing.
Precut your fabric to roughly the size/shape of the board, leave a good 3" of overlap per side. Do not cut your dome light opening yet. Then glue on using 3m spray adhesive liberally spraying the board. You will go through more than one can.
By not triming the fabric exactly beforehand, if you are slightly off in direction when applying the fabric it's not a problem. Being 1/8" off from a 90* angle on a 4-5 foot wide piece of fabric doesn't look like much. But after going 5 feet in length you can easily be off by an inch at the other end.
Laying the fabric down is a go slow and steady process, the glue is NOT some thing where you can lay it down then adjust and stretch it after before it dries.
Once it has dried you trim the edges and the light hole. Save some time and effort by making holes for the coat hooks before reinstalling as well, it's hard to find the proper spot once it's back up in the car.
