Heater Bypass Valve
565bbchevy
9,614
12,683
Michigan
So I just pulled the 307 Olds from my 86' Regal which has a heater bypass valve mounted directly to the intake and since I will running AC and will be installing a SBC I will have no provisions to mount it on the intake so I am thinking a universal style vacuum operated in hose one should work and I am wondering what I should use,
565bbchevy
9,614
12,683
Michigan
I found this one for a Ford, maybe an alternative to the plastic one?
https://www.summitracing.com/parts/mof-yg136
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Just mount it in the front of the SBC intake.
Thats what that hole is there for.
What intake are you using that doesnt have that hole?
69hurstolds
8,198
17,598
I don't think any Chevy engine owner in their right mind wants that big assed Olds goober valve hanging off the FRONT of their engine. It's bad enough Olds uses it on the back. Besides, isn't the hole sizes smaller on the Chevy intake? Would it fit?
spicercars
142
114
Saginaw MN
I must not be in my right mind then because I mounted it in the front hole of the intake. Heater hoses are very short so this is where I put mine. Don't even really notice it behind the alternator.
