Hey guys is it necessary to have a heater valve? Do i have to have vacuum to my A/C control unit for my heater to work?
Thanks!
Thanks!
pjpj1979 said:Hey guys is it necessary to have a heater valve? Do i have to have vacuum to my A/C control unit for my heater to work?
Thanks!
pontiacgp said:The heater valve is in the heater line going to your heater core that you open and close to varying degrees depending on the amount of heat you want in the car and it's controlled by vacuum......if you don't have a heater valve and the heater lines are still hooked up then you'll have constant hot air blowing inside the car
