HELP major carb issues
I didn't think they were very long. They're just detailed down to the last nut and bolt and only as long as required to convey the info.
so someone is gonna come over wednesday to help us tune it all up
Found this it might help you:
Tony's Quadrajet Tuning Tips and Articles
This page is made up of information I gathered from the Internet, requests I made by email, Bill Stacey from Buickstreet.com, Cliff? and many other sources. These are not all my personal experiences but a lot can be gleened from this information. Use it at your own risk, I can't accept any liability if you blow your engine up or anything 🙂.
QUADRAJET ARTICLE
Rochester's Quadrajet carburettors were a staple of General Motors V-8 powered vehicles from the late 1960s until the switch to electronic fuel injection was finished in the late 1980s. Capable of both fuel economy (for a V-8) and performance they made a name for themselves, although it is sometimes used as a curse.
When introduced it was the most complicated carburettor of its time, incorporating four-barrels and many functions (ie fast idle, choke). It was a fearsome rebuilding task for most technicians who were used to tuning Holleys and Carters. The myriad of linkages, internal circuits, and easily lost tiny pieces were incomprehensible to some. With age the Quadrajet earned a following of technicans who understood its design and recognized its potential.
The primary barrels of the carburettor are tiny compared to most four-barrel designs, but this is what gives the Quadrajet its gas milage edge. In contrast, the secondary barrels are huge, providing a performance edge. During normal driving the primary barrels are adequate for cruising speeds. The beast comes out when the pedal is depressed further. The secondaries open and there is the slightest amount of delay as the accelerator pump richens the mixture. A Quadrajet carburettor car is often distinguishable from other cars by the sound of the engine as the secondaries open. There is a moment of quiet followed by a large increase in exhaust volume, sometimes described as a 'booming' noise.
Most performance enthusiasts shun the Quadrajet as a stock carburettor laden with useless emissions controls. In reality, the Quadrajet offers performance on a par with most aftermarket carburettors while retaining good driveability and gas mileage. With a little modification most Quadrajets can easily reach 750cfm (cubic feet per minute) airflow. There were many iterations of the Quadrajet, even including some electronic versions produced while General Motors were dragging their feet in changing to electronic fuel injection. The most desirable are the ones produced in the mid-seventies on big-block powered high-performance and luxury cars. These can flow up to 800cfm in the stock configuration.
AIR VALVE ADJUSTMENT
A full 90 degreeing opening can inhibit fuel flow from the tubes. By 90 degrees I'm talking about the rear portion of the flap, the front will go past 90 degrees on a correctlyset up carb. The very best q-jets, Ram Air, Super Duty and Ho models were set so that the secondary flaps leading edge is 1.130" to the edge of the opening in the airhorn when fully open. Going beyond this can cause a lean spot as it effects how well fuel is pulled from the tubes and the lower edge of the flap nearly blocks the openings.
NEEDLE AND SEAT
I make my own hp needle/seat assemblies. I have found that .130" is the best all around size for hp use. You can go to .149" but it shows no performance gain. It is imperative that the fuel pressure be set at 3.5 to 4 psi, excessive pressure can cause problems with the larger needle/seat assemblies. To make your own hp seat, obtain a numbered drillbit set. Gently install the seat in a soft jawed vise. Drill from bottom to top being carefull to keep the bit straight. No matter how carefull you are a slight "dog ear" will be formed on the seating surface. Use a spare steel checkball and small punch to form a new seat. Vacuum test the seat by installing it in a carb with the float and needle. Invert the carb while holding the float pin in place. Use a vacuum pump hooked up to the fuel inlet via a 3/8 metal line.
APT is the adjustable part throttle. The carb in the picture should have a metal pin on the front of the power piston. The pin contacts an adjustment screw in the main casting. Most of the later metering rods have a tapered second step. By raising/lowering the adjustment screw you will have fine control of the part throttle mixtures. The later carbs will also have very small idle fuel supply holes in the baseplate. I would enlarge them to .090". Depending on your cam/compression ratio combination you may also need to enlarge the idle tube restrictions, idle channel restriction and add some idle bypass air. I would need to know all engine/drivetrain/vehicle specs to advise further in this area. For secondary rod selection obtain a set of AX .040" rods with long tips. They are a good starting point, I use them in the hot months. I use a custom machined .028" set of rods for cooler weather, and a set of custom .034" rods for moderate weather. As I mentioned earlier the late style carbs make very good hp units, but they will need some help in several areas. Another benefit is that they are 800cfm and work very well on large cid engines. I don't work on a lot of Buick's but suspect that you folks are running well using a lot of stock parts. My GTO uses a very mild medium compression 455. I have a stock iron intake and q-jet, Pontiac Ram Air cam and headers. My car runs very low 12's at 112 mph in full street trim thru the exhaust on Hoosier Quick Time Pro tires. Hope the info helps some....Cliff
GENERAL TIPS
The secondary choke pull-off is not needed. I would retain the primary pull-off and add an electric choke even if you are eliminating the shaft and flap. This will allow fast idle on cold start-ups and you won't have to "feather" the throttle for 2-3 minutes till it will idle on it's own. In addition to the mods you mentioned I would make sure the carb has a hp needle/seat (at least .130"), brass float and sufficient idle/off idle fuel for your engine. Set the float at exactly 9/32". I would also obtain or modify the primary choke pull-off for a 1.5-2 second release time, most are 3-5 seconds. The secondary airflap will have a limited opening angle, it should be increased by grinding the stop to duplicate the angle of the early HO and Ram Air carbs. I WOULD NOT change primary jets/rods, the carb has APT, this allows for fine metering control of the part throttle mixtures.
ADJUSTING AIR VALVE
Did you see how to adjust your air valve? You might have to take an allen key and a small screwdriver (I use one of those long electrical ones with the red insulation that goes down to the tip which usually came in Stanley screwdriver sets) because you have to tune it until any flat spots disappear. Loosen the spring tension slightly on the air valve until it starts to bog down a little and bring it back up until the bog disappears and a little more and your set. Then it's set for your car and you'll have bog free performance when you floor it from there on and it shouldn't change either. It seems like a lot of work but if you can find a section of isolated road. you'll know pretty quickly if you have a bog. Then you get out and adjust it a little and shut the bonnet and floor it again.
ADJUSTING AIR VALVE TENSION
If you follow that linkage to the arrow on the left in the picture you should see a little flat head screw through the linkage bracket. You'll have to move the linkage back a bit and slide your screwdriver in through the bracket and onto the screw. Directly under the screw is a small allen head grub screw which locks it into position - it's under so you won't be able to see it but trust me it's there. You might have to get a small mirror and a light to locate it for the first time.
1) use both hands to locate the allen head screw underneath and place the allen key on it but don't turn it!
2) Hold allen key in place with your left hand while using your right hand to place the flathead screwdriver onto the adjusting screw.
3) Making sure that you don't let go of the adjusting screw, loosen the allen head grub screw a little bit. Just enough to allow the screwdriver to turn the adjusting screw. The adjusting screw holds tension from a spring so if you loosen the locking screw without holding the adjusting screw it will unwind like a window blind and you'll have to start over again from zero tension (which is another story).
4) loosen the adjusting screw no more than 1/4 of a turn and preferably 1/8 at a time and tighten the locking screw. You won't be able to see how the air valve butterflies "flop" until you take the screwdriver out and allow the linkage to go free but I suggest that after 1/4 turn you go out and drive it. It should flop open easily but also have enough spring pressure to make sure it closes or it's bog city for you. Floor it under all sorts of conditions and keep loosening it until it starts to bog when you floor it then come back 1/8 of a turn from that point. If you can loosen it 1/4 to 1/2 a turn and still not bog then it needed it. If it bogs on 1/8 to 1/4 of a turn then it was about right and you should leave it. In any case, loosen it until it bogs and 1/8 turn back from that and you should be right. I'll be very surprised if you loosen beyond 3/4 of a turn of where it is now. The leaner the rods the less quickly you can open the airvalves without it bogging. When you have a loose air valve flap you better have the rods to back it up (which we have with the AX/B combo) because there's going to be a whole lot air coming in pretty quickly and it's going to need a lot of fuel.
I hope you understand all that because I typed it all off the top of my head without looking back.
Metering Rod Chart
http://www.hioutput.com/tech/qjetrod.html
http://www.corvettefaq.com/c3/myqjet.htm
well after all this anger about who is right and who is wrong. i appreciate all the knowledge that i have gained from this. however me being only 18 my father had some guys from a local parts shop come over. turns out we installed the wrong harmonic balancer. so in turn it is timed 13 degrees retarded or something. anyways these guys are coming back early next week to get the problem all fixed. Carpet should also be coming in so the car is really coming together. thanks again for the help everyone
All that matters is that you learned something from all the mess ppl talk.
and you should always keep in mind that there are so many variables with non computerized cars that specs and factory settings will not always give you optimum performance out of your vehicle.....with the addition of ethanol in the gas that we use causes a problem at idle as the usual 14 to 1 mixture ends up to be leaner as the molecules of the ethanol are too large to fit through the jets in a gas carburetor and injectors of a injected vehicle which is even causing havoc with computerized vehicles..so for the carb cars they have to be adjusted to compensate...
okay we can put it to rest 😀 thanks guys
