ditch the computer crap get a normal carb, distributor and lock up kit for the trans
Never worry about it again!
Sounds like an option. Know of any reputable shops in the NY area that can do this for me without getting raped, lol?ditch the computer crap get a normal carb, distributor and lock up kit for the trans
Yes, I’m going to try the egr trick soon. Code 42 can be very tricky from what I’m hearing. I Had the same problem with a 91 camaro and I sold the car to my brother in law without fixing it. Turned out the the ECM was the culprit. Now, is the distributor in the 307 olds engine computer and vacuum controlled?wouldn't it be easier to see if the suggstion with the EGR works and if it doesn't to try another ECM before having to change parts that may be good
computerYes, I’m going to try the egr trick soon. Code 42 can be very tricky from what I’m hearing. I Had the same problem with a 91 camaro and I sold the car to my brother in law without fixing it. Turned out the the ECM was the culprit. Now, is the distributor in the 307 olds engine computer and vacuum controlled?
I agree...definitely an ignition problem and not fuel related. Yes, wired away properly and replaced all the parts with AC delco. No, engine Has not been taken apart. She currently has 116k. Either hot or cold. I actually drove the car the other day for 5 min straight and she ran fine. Then just outta no where, she began misfiring and died at a light. Started back up and the CEL light stood on. Whatever it is, I’m sure it’s simple. I will look at the ECM Over the weekend . I gambled on $150 replacing the parts on my original thread. Unsure if I should throw in the towel and take it to a shop.Sounds like ignition to me. Are plugs wires routed properly away from any modules as could be interference. Did you put the right parts in? Has engine been apart as a ground wire could be an issue? Does it occur when vehicle is hot or cold? Disconnect and reconnect ECM connectors carefully a couple times. Leave ECM on floor board and see if acts up. Let me know and we can proceed further
