Do it the way you feel is right. I went with forged rods and pistons but kept stock crank and I took grief from some on here or maybe LS1 tech... cannot remember. Mine is only going to be naturally aspirated high compression.We spoke over different scenarios for a brief moment. I kinda didn’t want to do just a typical build maybe a step right above your average junk yard build. Thanks for the advice
Why not go stand alone with Holley or Fast. Much cleaner install and by the time you spend money on tuning you'll be about even ?Also got on lt1swap.com to figure out the harness for stand-alone. Super intimidating at first, but with vigorous reading the instructions made me feel like I actually knew what I was doing... any advice where to send the computer for flashing?
I mean no offense to above posters about using stock parts because I know they are capable of handling abuse, however, I feel if you want to do it right and not have to worry about scattering your block at 130mph on the big end, then going forged and proper machining is cheap insurance (somewhat).
My goal is to reach 800 with turbo, I figured an aftermarket bottom end would get me closer to my goal. Granted the 6.0 would get me there easier. But the 5.3 is what I hadDon't take this the wrong way - if your goals are reasonable (less than 800HP), then the stock stuff is all you need. Expensive parts break just the same as the Gen 4 parts will if the tune stinks. BUT (notice caps), there is nothing wrong with building a sound short block - NOT A THING. Especially if you have the jing to support that plan. FWIW we practice what we preach - we have $6500 in our short block topped with a set of $300 317 truck heads. The idea being that we won't have a bottom end failure until we see 1100+ HP. We haven't hit that kind of power yet, but we keep chugging along - lol.
A couple of things to keep in mind - 1st, you need to learn how to tune in a hurry or need someone that is reliable near you. Personally, I prefer to tune myself and live and learn as I go. But I am a true believer in 'creeping up on the tune' - meaning if I think it'll take 18 degrees, then I put 14 to it and check the plugs after a couple of pulls; 2nd - don't skimp on the fuel system; 3rd - a 5.3 is forgiving due to the short stroke-it will take a ton of boost without an issue; 4th (lastly) - don't skimp on the cam - no less than a BTR Stage 3 unless you intend put 10's of thousands of mile per year on this.
Regarding the last item, we chose a milder cam because ours gets driven alot (sometimes too many) miles every year, but we decided to make up for it with cubic inches and a big turbo for a street car.
Almost forgot - HP Tuners is expensive, Megasquirt and Holley software are free. Something to consider when you look at aftermarket ECM's.
I wouldn't bother with E85 unless you're that desperate.This might be good advice for an NA build..... but for a turbo build, its tough to beat 105 octane fuel for $2/gal.
