hey if you got the bank, go for it! I will look at my high end wheel catalogoe tomarow and see if I see anything else that might look good.
midwestls said:I like big wheels! Do it. But right.
2000.malibu.ls said:hey if you got the bank, go for it! I will look at my high end wheel catalogoe tomarow and see if I see anything else that might look good.
87Cutlass442 said:midwestls said:I like big wheels! Do it. But right.
Oh, don't worry...I shall. A good friend of mine owns a rim shop, so he's giving me all the ins and outs of them. The good part about 3-piece wheels are they're made specifically for the car...bolt pattern, offset, etc...it's a custom fit.
BUT, above all...the motor will come first. The rims will be the last thing I purchase.
2000.malibu.ls said:87Cutlass442 said:midwestls said:I like big wheels! Do it. But right.
what kinda motor stuff you looking into?
Vern said:I like an Olds powering an Olds but its not what I did. I like big block cars with good gears an overdrive with lock up converter good heads and a moderate cam with a q-jet like I did with the 509 or Bob Powers did with the 455 Olds in the above link. Bob ran 12.3 at 110 mph and cruised effortlessly at 15mpg with AC. So far I ran a 12.5 at 110 mph and have gotten 17mpg. No spinning the snot out of it & low maintenence. Then again my goals are street car that I can drive on a Hot Rod Powertour or to the Year One race & car show etc which is out of state. If you are just hot rodding around town then you can do different.
Its unusual that you want that big of a rim and are also talking performance because usually they are just for looks as you cannot get the low profile tires too hook when you start makeing some real power. I always though 20s are about as large as you can go without being too big to look right with the factory body lines.
Back to the car and motor. You have a great performance platform with the full frame, 8.5 rear, reasonable weight, useable guages etc. Oh yea I hooked up the factory tach & oil pressure guage to the Cadillac motor but a 6 grand tach won't cut it for a high winding smallblock or LS motor. Another good thing about the gbody is they (the GN & 4.3tbi monte) came with fuel injection so you can get used intank pumps hangers and sending units baffled fuel injected tanks even new fi tanks so its not like old school cars where you have to do a sump and out of tank gravity fed electric. Benefit of a gbody. I like the idea and would be tempted to do a LS motor now that the aftermarket has enough support for an eazy conversion. Montecarloss.com has a sticky on it in their engines section. With the fi parts drop in ready for the gbody I would not go backward to useing a carb with a LS motor.
