You would for sure have to change the brackets on the AC pump over to ones that will work with your SBC accessorys, (make sure you get compete set of accessory brackets with your Chevy as none of the Olds stuff will work). More than likely the actual AC pump will not work with the Chevy brackets. Even if it does, the lines won't reach because the pump will be sitting in a slightly different location on the SBC. You will more than likely have to Release the refrigerant.
