Hey Guys,im a newbie so be nice lol, Sbc in a 87 cutlass
bryguy39
Apr 25, 2007
89
6
I need to know everything i need to put a 350 chevy in to my 87 cutlass that has the 307 olds. What motor mounts do i need? and wiring do i have to change, and what problems will i run in to? also im going to run a Turbo350 trans, so what cross brace will i need to have?
Thanks to all , Bryan
357chevIn86
8
MISSOURI
i'm doing a similiar pro
i'm doing a similiar project. i used solid motor mounts but u can go to ur local parts store and just get (frame) motor mounts for a 78-88 monte they probably cost around 10 bux each or less. as for the crossmember the best way to go is to call summit and get one from there. they sell double hump x- members for around 210 bux. and block mounts any junk yard will probably give them to u.
82355supreme
244
Wisconsin
Don't get the crossmember from Summit, get one from Jegs. They are $115 from Jegs & are quality built. Not saying Summits aren't quality, but I'm saving ya' $100. :wink:
jerrycad472
264
16
Detroit, MI
Search the site. There have been numerous threads about the swap you want to do. Its not too hard.
KMac
132
i'm currently looking into this swap. Jeg's definately has the best crossmember because every car on the track is running it (G-body's that is). It doesnt seem too hard to do considering some of the swaps i've done before
bryguy39
Apr 25, 2007
89
6
Thanks guys for all the help,ill let you know how the project turns out. also do i have to do anything special with the wireing? also i have ac in my car right now,what do i have to buy so i can use the same compresser and not loose my freeon?
Thanks again, Bryan
82355supreme
244
Wisconsin
The wiring is straight forward, cables from battery to starter,ground, & alternator. And wires from key to starter.
Fuel line will have to be extended to passenger side.
You're F'd with the A/C, as far as saving the "charge". With the proper brackets,belts, & pullys you can hook the A/C back up of course.
Chevyman85
594
Bonney Lake, WA
bryguy39 said:
why is that?
Thanks, bryan
When you unhook the AC your going to loose all of the R-12. You'll have to take it to a shop or buy the recharge kits to load it back up. I believe that was what you were asking about.
bryguy39
Apr 25, 2007
89
6
i guess i dont understand,why would i loose the R-12 if i keep the compresser hooked up and use it on the 350 chevy? or is it not able to bolt to a 350 chevy?thanks bryan
