I adjusted it based off the tension on cable , the cable was WAY LOOSE ! Car was just hot already after I did the initial adjustment so I had to let cool down. I can feel the throttle response & car is accelerating faster so I guess I’m on the right track??? Adjusted how? Did you follow Anubis or lilbowtie's instructions? Line pressure gauge? I ask as it appears that you're adjusting the TV cable via shift feel - if you are, then this IS WRONG.
