Holley carb and 200-4r, what throttle stud?
richp85elco
409
Long Beach, CA
Can anyone running a holley carb and 200-4r show me a pic of there throttle and tv linkage, and the parts you are using? I want to get the geometry corrector but I don't know what size throttle stud to run with it, there are different lengths and sizes. I am using the stock bracket if it matters
This is an example I found, what size is the stud for the throttle cable?
307 Regal
1,667
915
Northern Indiana
I could try to get a picture of my setup tomorrow. I've got the adapter piece for the 200-4R like the one pictured. My throttle setup might look a little "rigged" or "homemade" lets say. I just used parts that were laying around. I ended up using the top hole in the stock Holley bracket just to take up more slack so I could get my gas pedal farther off the floor. With the aftermarket throttle/trans bracket I'm using I can still get to WOT with that top hole on the carb's bracket.
307 Regal
1,667
915
Northern Indiana
well I never got that picture, but after further review, my setup is far too rigged to be of any real help as far as finding a throttle stud size for you. I am using the geometry corrector (summit brand I believe) and it works just fine, if that's any help at all.
JBreu
2,167
20
38
Livonia, New York
Here is my setup.With a 700r4 but the cable is the same...YOu need a 7/32 stud :)
richp85elco
409
Long Beach, CA
quote]
You sir, are the man. Thats a bad *ss looking motor 8) What kind of bracket is that, the stock one leaves the Tv cable at an angle from where it mounts to the geometry corrector
JBreu
2,167
20
38
Livonia, New York
richp85elco said:
quote]
Thank you...I bought the geometry corrector and throttle bracket from Jegs, it's their brand.....http://www.jegs.com/i/JEGS-Performance- ... 0/10002/-1
