pontiacgp said:but I really want a V8 Accord as it would be quite unique. I like the 2door 90-93 Accords and I do want to keep it looking stock besides the wheels and ride height.
I don't know how you'll do it and keep it looking stock. The front fender of the accord is at least a foot shorter and the height of the nose gotta be less than half of the G body so how much of the engine will be in the passenger compartment?
betcha618 said:why not just use the drivetrain from a newer monte. 5.3L v8 and its already front wheel drive. I had thoughts about putting one into my Maxima.
IronyOfFate said:pontiacgp said:but I really want a V8 Accord as it would be quite unique. I like the 2door 90-93 Accords and I do want to keep it looking stock besides the wheels and ride height.
how much of the engine will be in the passenger compartment.. I guess I would have to figure that out in the process. I am just looking at different options right now, I won't be 100% sure until I actually do some measurements on some RWD cars I can use
IronyOfFate said:betcha618 said:why not just use the drivetrain from a newer monte. 5.3L v8 and its already front wheel drive. I had thoughts about putting one into my Maxima.
good idea but I am trying not to spend too much on this
85 Cutlass Brougham said:IronyOfFate said:betcha618 said:why not just use the drivetrain from a newer monte. 5.3L v8 and its already front wheel drive. I had thoughts about putting one into my Maxima.
Trust me, it's gonna be more expensive than you can conceive and require a lot of fabrication to do it right and not build a death trap. The reason I suggested the Mazda and Nissan parts is that they may be closer in size to the Accord, and because most of their suspensions bolt to a simple crossmember so you don't need to worry about the geometry of anything but the struts. (Theoretically, you could also eliminate the rear strut towers by laying the dampner/spring package flat and actuating them using a set of cantilevers. Look at an Ariel Atom to see what I mean.) By doing it with a pair of complete suspensions, you could fabricate a frame or set of subframes to weld into the Accord and bolt the suspension crossmembers to. (I came up with this approach when I planned a Nissan B13 Sentra/Tsuru/Sunny that I was planning to convert to AWD using parts from a RNN14 Pulsar GTiR. BTW, it never got beyond the planning stage due to time and cost.) For mounts, I would get a set of universal LS side mounts and build your own to get the engine positioned as low and far back as possible. You will also need to fabricate most or all of the floor in the passenger area, and make it all work with a transmission tunnel the car lacks currently. This will mean you may need to work on pedal geometry, and don't forget about the brake proportioning and proper master cylinder sizing if you plan to stop. Then, you will need to couple the stock steering column or swap it to one from the front suspension donor vehicle. You also need to be sure that the wheels you choose are offset in such a way as to put the wheel bearings in the center of the wheel's width so that the bearings get proper loading. Yes, you can get away with not doing that, but the bearings will need more frequent replacement. You will also need to relocate the gas tank from under the back seat to either behind the axle (somewhat dangerous in an accident) or above the axle and behind the seat, like a Jaguar XJ-6, Holden GTO or Infiniti J-30. This is because the driveshaft will need to go where the tank is now, and the pinion snout will also be likely to intrude into the tank's real estate. If you could figure it out, you could also put it under the front seats as a single or dual tank setup, like the one in a Honda Jazz/Fit, which would allow you to use the space below the back seat for suspension or exhaust components, or even a switch to the Fit's versatile back seat. Now, an independent rear suspension minimizes the space needed here because the driveshaft does not need to move up or down. However, safety would dictate the fabrication of a driveshaft safety loop to keep it from puncturing the fuel tank in case of a failure (if the stock tank stayed). Also, because you wish to use an LSX, you will need a baffled fuel tank to avoid drops in fuel supply around corners which can quickly kill the pump. Then, you will need an exhaust system, and you will need to plan around it while designing the car as it does take up real estate under the car. There's nothing worse than an exhaust that hangs too low and get's ruined after a few speed bumps.
There is more if you would like me to list it. I am not trying to be a dick here. I don't know the level of knowledge, money or skill that you possess. I just don't like to see people waste money and get in over their heads with what seemed to be a simple idea that mushroomed out of control. (Been there!) Your statement that you don't wish to spend too much here makes me think you don't really know what you are proposing here, because it IS going to be expensive. It's expensive even to just swap a stock LSX into a normal G body. By the time you get the engine, engine management, exhaust, transmission, driveshaft, fuel system, electronics, hoses and hard lines, cooling system, etc. done it costs between $5,000 and $10,000, if you do it right. And that's in a car that it bolts in to with a simple mount kit. An LT1 is cheaper, but would still run you over $2500 to do everything properly. If you wish to still do it, I wish you all the luck in the world. I'd even offer to help out with it as I love this sort of thing. However, I would suggest trying a less ambitious project instead with less engineering required since cost is an issue.
Hey, if you want different, try a 1980's Mercedes Benz 240D (Type W123) with the LSX swap. It's RWD already, overengineered, also came in an EFI gasser version (so you can use the stock tank). No one does anything with them other than run waste veggie oil in them, so who would think it was fast? Plus, the wide variety of engines means a wide variety of gearing choices in junkyards too. However, my all time favorite is the BMW E30 3 series with these engines. Again, cheap to buy, RWD, and overbuilt German cars with low weight. I think with the LSX it weighs 2700lbs. It has been done by many people and there are great parts interchanges with other 3,5,6 and 7 series BMW's of the same era. If you want any other ideas, I am full of them due to my love of quirky, unconventional thinking.
