Hood Bolts
mikester
3,042
4,065
Small town NY
Finally got the hood on my car tonight. Lined up well. Couldnt find the spring at first but after some searching in the attic I found it.
A question though. What kind of screw goes into the side of the hood at the rear corners ? My 81 has a rectangular piece of plastic in the hole. The wagon has a U nut. Not sure if thats what should be there. I probably have more of the plastic pieces but I have to dig for them. Still dont know what the screw looks like. Anyone know ?
It also seems like the corners are up a little. Not sure if theres an adjustment on the hinges. Lines are good otherwise. Wipers look like theyre going to clear. Close though.
On my car it is a Metric 4.2 - 1.41 X somewhere between 16 and 20mm long, 7 mm Hex head with with a loose washer that's not removeable. It screws into the plastic insert. Like the pic but i am not sure if the washer is that big.
I'll check to see if theyre the right size tomorrow. Whats the purpose of the two screws ?
Supports the rear of the hood, the corners are a long ways from the hinge attachment, and the metal is fairly weak back there.
