how do you install mini spool
if its a 3 piece spool pull the rear wheels drums and then the diff cover. pull the pin out of the housing puch the axles in do drop the C clips then pull the axles out a ways and pull the spider gears and axle gears put in the spool axle gears and then push the axle gears back in and re insert C clips and pull the axles back into place. then insert the two blocks and line the hole up with the carrier hole and reinsert the pin and bolt the pin in. put on yoyu diff cover refill with grease and put drums and wheels back on. dont forget to make sure the blocks are in there ight with no play you can adjust this with the shims on the axle gears.
