First coulple of times I towed a car on a trailer I did the same thing using the frame. Learned that lesson quick. They were project cars I got for parts, but same physics apply. I now use axle and/or tire tie down method. And yeah, there's a lot of ways you can do it.I use "J" hooks with chain at the control arm under the ball joints in front straight to the front "D" ring on the trailer bed on each side. At the rear I use an axle tow strap and separate ratchet strap in a straight line to the rear "D" rings in the trailer bed. After talking with a local tow operator on crossing the rear straps I was enlightened to the fact that IF a strap or chain was to fail the entire vehicle is then free to move, while with a straight front to back strapping method, should a chain or strap fail you are still secured by the opposite side.
As a secondary safety measure I also use a tow anchor that fits the oval frame holes in front and attach with a slightly slack chain to one of the "D" rings in front. Overkill yes but...You never know.
