How to charge new A/C System
mhsmonte
131
Kentucky
Recently I added A/C to my LS swap and I was curious of what I need to do to charge a system that has a new condenser, new hoses, new compressor, and new accumulator/drier... I want the system fill with r134. Any advice would be greatly appreciated!
12,180
9,808
I'm in the same boat. I installed a new compressor, condenser, evaporator, new drier (not yet installed), orifice tube, and new hoses.
The system will need to have a vacuum pump hooked up to remove any existing moisture, and check for leaks prior to recharging with 134A. .
Have you added oil to the compressor/ system? Make sure you replace all the O-rings, too.
I'm going to have a guy do the finishing touches...pull a vacuum and recharge the system.
84/ttop
22
4
Washburn, ND
Yep, longroof is right, needs oil, pull a vacuum and do a leak test before puting a charge of 134a. I haven't done any full system on a car, but the last one I did on a newer JD tractor had the oil for the whole system in the new compressor but most AC machines can inject the oil into the system when charging as well.
12,180
9,808
Hey, good for you. I was supposed bring mine in this week, but other stuff came up. $50.00 bucks is a good deal.
