How to make 26s fit
I already ordered rims from Armani forged so I can only go forward
So you ordered rims without any idea on how you are going to make them fit? IMO I like to take a bunch of measurements first off existing rims to see what type of clearance issues I might have, but good luck with your set up.
Reactions: Longroof79
Cheap way, use a truck body off frame lift they come in different sizes 1",2" an so on.
Then it will depend on tires your putting on the rims . Will have to rework the bumper hangers/brackets.
Air-ride suspension? $$$$
I know it's a truck but it's only got a 3" body off kit an l was able to put 38" tires on it. Just for reference.
Thank u I brought a 2002 Silverado just for the motor but I junked the truck wish I would have known this smh
You can get the body lift kits any where, there cheap ($100-$200) They come with everything you need to add space between frame and body.
If l was going to do a car, l'd only add enough and still keep frame hidden by the body. So a 1" lift block will give you 2" of added tire from normal an so on.
Wiring an steering shaft will extend enough for up to a 3" block so no worries there.
Qdub is the resident big wheel expert; I want to say he says 24s go no problem. HOWEVER, it really comes down to tire size. Ideally, 26" is overall height including the tire, but that's out the window when it's your rim size. I see fabrication in your future.
I totally get building a car around a set of wheels, but the operative word is "building". NOT, "what's the least amount of work I need to do"; that ain't gonna fly.
😥 I went into this build not knowing what I was up against I already paid a ton of $ for my rims now I have to forward thank u for ur advice
So u think 3 inch lift cups would work with the original springs
