How to remove and install distributor gear?
With a little force. It's just stuck. Confirm that the new gear has the correct inside diameter - they aren't all the same.
Reactions: fleming442
Its a new distributor that someone installed a bronze gear on it and I'm wanting to put the original melonized gear back on it,how do I remove the bronze gear that won't come off i have the pin out?
Hold onto the rotor in one hand and put a small set of channel locks on the gear with your other hand and twist.
Be sure the pin is completely removed.
Can you post a pic - doesn't sound like everything is copacetic.
Reactions: 565bbchevy
Here is the picture pin is clearly out and if I get it off with channel locks how does the new gear goes on does it have to be pressed on or what?Thanks
