Not as heavy as the one in the passenger side door was... But that one had absorbed a lot of waterIsn't 100# about equal to 10hp or .1 seconds in the 14 second range? How heavy was that nest?
To be honest, that reinforcement is just about garbage now have lost so much rigidity from all those holes. All you needed to do was stand it on end and stuff a stick down the middle.Just kidding these are shop vac access holes. Effing mice.
Yes, there's guys who run just export brackets or aluminum struts. Doesn't make it a good idea, that metal was needed to meet crash standards. As strong or thick as you think that chrome shell is, it'll slice in half on its own in an impact. All those holes make a myriad of weak points to just fold over.
Now that's just my opinion, run what you want. But cutting away structural reinforcement metal is never a good idea.
The aluminum are worse than the steel, and I've seen some of both so corroded on a number of the hundreds I chopped and/or rebuilt that photo sized sheets of metal could be broken off by hand.While it is weaker, I don't think his life is in danger any more than before. Those things tear like tin foil in a real wreck.
