Hvac delete panel questions
Tony1968
2,324
5,134
NW Indiana
Is there something specific I should use between the plate and the firewall to seal it?
I might have some seam sealer laying around or can I just use some RTV ? I don't think it's necessary to buy the original gasket. ???
Thanks
19,992
rtv is fine
but you may regret getting rid of a defroster
19,992
sweet
What unit are you using
5,711
12,223
I've used foam tape (sticky on one side). It allows the panel to be removed easily.
We use hot air for defrosting, the only issue is the hyperventilating that ensues after the windshield is cleared ;)
melloelky
4,167
9,587
mass
get the bride in the car it'll be all the hot air you'll need.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,811
Louisville, KY
Tony, there is actually a foam gasket available from Mike's Montes that goes behind the delete plate. I actually have two delete plates, because ya know, redundancy lol! I have an inner plate that is welded on, then has RTV along the seams. All of my electronics are mounted to it. Then I have the gasket with a small amount of RTV with the outer delete plate screwed to the firewall.
melloelky
4,167
9,587
mass
those gaskets are money well spent.a little strip chalk under the head of the bolts and/or on the threads is cheap insurance.
