Gotta get back home first, at work currentlyDid you get your rod out of the attic yet?
The Fun Police had to make sure it was Google compliant, but I didn't see anything beyond PG-13.......![]()
you need to put more money in the meter....
So I wasn’t practicing the interweb’s dark arts again?I think it's been edited. It was starting to go south.
Where is the camera?!?! How do you know that?!these days that usually means you walk up the stairs from your basement when your work day is finished....![]()
I don’t believe I can. The sleeve that the rod sits in on the hydroboost is crimped in. The one in the vacuum booster looks to be held in with a snap ring.3" isn't a lot until it's on the end of your rod. Can you switch them?
It mounts with a removable 4 bolt flange. Diameter of the hole the hydroboost runs through is around an inch and 5/8.how does the hydroboost mount to the firewall?
