I paid about $22.00 for my dual Intrepid fans from pick and pull. My engine compartment looks a lot cleaner with them because they are slim & the motors don't stick eat out like other fans. They work great & my engine temp. never goes above 190 degrees. Instead of buying a relay kit I made my own & wired everything up. The bad about these fans is they pull a lot of power. At idle & stop n go it was hard for my stock alternator to keep up with the demand for power and my voltage would drop to about 10 volts. After doing a little research I ended up doing a alternator swap to the cs144 now I don't have any problems & the voltage stay at 13.7 at idle with the elec cooling fans, blower motor on high, radio blasting &headlights on.
