I need an electric cooling fan? Help me
My set up is from a 93 Camaro the shroud and dual fans work very well .I run two fan relays triggered by a 160 deg temp switch. I also have a 14 in pusher in ft of the ac condenser that runs on a separate rely so you can run the ac before the engine temp switch kicks in the main fans . Its kinda hard to see them because i have an auxiliary trans cooler sitting on top of them rt now. :popcorn:
Here are the pics of my fans & the new alternator. The fans will sit in a lot better when I swap everything over into my new body. I just threw them in and mounted them real quick to see how they work.
this alternader setup looks scary to me. that turnbuckle just doesnt sit right.
:rofl: It works perfect for me! The belt is nice & tight & the alternator doesn't move at all! 😀
wow............and the ultra clean wiring.................. :puke:
I coulda sworn I said this is a temporary until my other cutlass is ready... I'll love to see what the wiring look like under the hood of that 78 Elco....
You talkin to me? :itchy:
Thanks for the pics. I probably will go with an aftermarket fan(s) just for the ease of install and cleaner looks. Which leads me back to my original question. How do you know how much fan to buy?
