So, Ive been redoing the brakes on my 81 Malibu. This all started with the DOT 5 brake fluid fiasco.
Back when I bled the brakes with the DOT 5 in it I never liked the way the pedal felt. It wasnt spongy but it didnt feel like it was totally bled. The pedal seemed soft and low. I assumed it was just a characteristic of the silicone fluid.
Just before I started working on the coupe I finished up the brake system on the 83 wagon. Bleeding the system didnt take that long and the pedals high and firm.
Now that Ive bled the coupe I see a huge difference in the way it feels when you step on the brake. Night and day.
I put in a new Delco master, new Raybestos calipers, new proportioning valve, new rubber lines and new wheel cylinders. All the SS hard lines were flushed out with denatured alcohol and brake cleaner and blown out with air. I bench bled the master and bled the system 2 different ways. First with a Mightyvac suction bleeder and then the old fashioned way. Lines are clear. No air. None !
I still have a soft low pedal. Exactly like I had with the old fluid. Completely different than the wagon. Im stumped.
The only thing Im thinking "might" be the problem is the booster. The 81 came with a large diameter single diaphragm booster when I bought it. At the time I thought a double diaphragm smaller diameter would be better. Instead of buying one from a place like rockauto I bought a generic booster from Pirate Jacks Brakes. The sales guy said it would work with no issues. Now Im wondering. Could it be the booster ? Maybe the rod that goes into the master is too short ?
I looked on rockautos site and theres different part numbers for each year. I would have thought the masters and boosters would all be the same for g body cars up to 1988.
What should I do at this point ? I mean the only thing I havent replaced over the past few days is that booster. Could it be the issue ? And if I replace it should I buy the correct part number for the year/model ? What the heck cold be the difference from 81 to 83 ? Its the only two things in the entire system that have different part numbers.
What do you guys think ?
