install multi gauge
scarborough
307
66
installing a set of auto meter multi gauges in a 87 cutlass trying to wire the gauge lights, not sure which color wire on the light switch i need to splice into. Any advice would be appreciated
melloelky
4,162
9,569
mass
look in your fuse panel there should be a tap that is energized when you turn the lights on.
abbey castro
1,048
1,318
Harker Hts TX
Tap into the fuse box upper left corner: "INST LPS" When you turn on your instrument lamps your gauges will come on too.
