Thanks for the quick reply, its an 87 Monte, I have what looks to be 2 grounds, a heavy purple, a heavy green (these may actually be vacuum?) Then a blue, an orange a yellow and a green, actually maybe this will help.jacobdavis1979 said:What kinda car is this? In my bu the only electrical connections i remember in there was to the blower motor. Everything else was a mess of hoses if i remember right and the whole thing slid right out and i put my plate on the firewall
The AC box had been previously "modified" by the PO, so when I removed it there may have been a sawzall involved lol. So I could, in theory, simply cut, or bundle, or unplug that group of wires with no Ill effects?81Regal said:The purple and grey, you call them green, are vac lines coming from the engine to the contols then back to the heater shutoff valve. The rest of the wires you show are for the Hvac fan controls. The Ecm and harness is a seperate bundle that is below the A/C box. You can remove the wiring shown in the picture by unhooking a single brown wire by the controls, ground wire, and the 4 wire connector by the passenger side valve cover. It would have all come out with the A/c box.
