Ifpimplogic said:i know i may sound like a noob asking this but what is IIRC?
Clutch_Grabwell said:'Front' IROC wheels will fit your Bu at all four corners. If you end with a 'rear' pair, a set of 3/4" thick adapters will be all you need.
See below my partially assembled SS back in '04. At the time the 'front' wheels (0 offset) were on the rear axle and the 'rear' wheels (16 mm offset) were mounted on front along with B-body spindles and 12" brakes. The wheels are now mounted on the intended ends of the car after replacing the spindles and the adapters are correcting for the offset at the rear end.
Thanks for jumping in. When I saw the thread go all day without a reply, I posted what little I knew just so 79SkyBu would know that they are not exactly a bolt-on. Any part is a bad deal, no matter how cheap, if it doesn't fit.
Bill
