Highwood Malibu said:Cut out bad rust then find a guy who does good work with fiberglass.
Qdub24 said:Highwood Malibu said:Cut out bad rust then find a guy who does good work with fiberglass.
Don't do that! Fiberglass will crack and split from normal driving and you'll be back to square one. I tried that on my Cutlass' roof and that's what happened. Cut out as much of the rust as you can, and weld in new sheetmetal, or maybe an entire roof from a donor car.
67rstbkt said:Qdub24 said:Highwood Malibu said:Cut out bad rust then find a guy who does good work with fiberglass.
X2 on this, DO NOT Fiberglass this if you want to fix the car correctly. The only way to deal with this is to cut out the rusted portions and replace with good metal; either by fabricating metal patches or obtaining replacement metal from a donor vehicle.
