No.Understood...
Let me ask you this...
On all SBC harmonic balancers, the timing groove always lines up with the harmonic balancer keyway ?
Yea I'm familiar with this information... My engine is an 83-84 305... It's either noon or 2 o'clock...No.
I found this on another web site that gives some insight.
The pre-1969 damper has the TDC line on the outer ring at the 2:30 o’clock position- or 2º before the keyway centerline- i.e. the line is to the LEFT of the keyway, looking at the front of the damper or engine. The keyway is seen in the ID of the damper nose.
The damper used from 1969 to about 1984 has the TDC line at the 2 o’clock position- or 10º before the keyway. You'll find that aftermarket dampers are the 10º type, as are the bolt-on tabs sold by the aftermarket, unless they're adjustable.
Warning Note: This includes the SBC 400, although the 400 damper is counterweighted because the engine is externally balanced. Do not mix and match internal and external balanced dampers!
A third timing mark was used from (some) 1978 to about 1995, and nearly all 1984-1995. It is at the 12 o’clock position- or 40º before the keyway. This damper uses a timing cover that has the tab welded on at about the 12 o'clock position. Professional Products lists the years for this type damper line as being 1984-1995 and is a 6-3/4” diameter damper.
I knew it ! I've been fighting trying to find my correct timing setting since July 2021Yea I'm familiar with this information... My engine is an 83-84 305... It's either noon or 2 o'clock...
Its on TDC now, timing cover and chain removed... Going to put on the balancer now and take a pic...
That's why the balancer cover doesn't fit, I'm assuming... or...the timing mark slipped perfectly into the noon position lol...what are the odds ?I knew it ! I've been fighting trying to find my correct timing setting since July 2021
Whoever rebuilt this engine installed the wrong timing tab...which had 0° in the 2' o'clock position, thinking my correct timing setting was the 2 o'clock position... View attachment 192002
But after setting TDC correctly with the timing cover off and chain set attached...and now putting the balancer on the crankshaft at TDC, I see now my timing mark (painted Red) is actually noon and not 2 o'clock... 😎... View attachment 192003
Thanks you guys...
