Is this harmonic balancer cover with timing marks fitted correctly on my 305 8" balancer ?
Tynan918
1,136
249
35
Anybody familiar with these ?
No mark on this cover lines up with the timing mark on the balancer...
That is the correct tap. Here is the problem threads should be repaired if they can be with a thread chaser it does not cut any metal just tries to realign the threads. Never seen a thread chaser that is long enough to do this so a tap is needed. If the threads are bad enough the tap will cut out the damage and might make the threads weak or even non existent.
Perhaps 64nailhead is correct and the deeper threads are still good.
Reactions: ssn696 and Tynan918
Well maybe the threads don't need tapped... I just installed the harmonic balance bolt and given the depth it went in, I need to consider the balancer, the bolt washer, and the crankshaft pully being attached and it should all tighten down...
Also at TDC, the harmonic balancer points at 12 o'clock... That is the official timing position for my engine.
