I think i figured it out. That crown looking piece goes first. The bearings surround it. Then that ring goes on so the springs stays in place🤔
Â
Isn't that the same repair kit for a Fiero...🤔There's always the last resort if nothing goes your way...use the Ford repair kit. Simple to use.
Is he a friend of yours? I noticed he calls you out at the end and says "que the music"As far as changing out the ignition keyswitch tumbler, it's luckily the only key operated thing on your car that has one key that goes to nothing else, so you can get a new key/tumbler assembly and swap them out- and it's not that hard as long as you have a lock plate compressor and a steering wheel puller. Then it's easy peasy.
GM p/n for the key switch (comes with 2 keys) is p/n 19356477. Again, you can cheap out and go with the box store brand, up to you.
Amazon sells them for about 26 bucks plus applicable tax. List price is $45 and change.
Hutch does a great job on how to disassemble a steering column to remove the lock cylinder. Watch it completely if you want to understand how this all works, but about up to the 16:30 mark is him getting to and taking out the lock cylinder.
Haha. Yeah, I told him in his videos he should put some 70s p*rn music in them, so he said he would, and that was the one he did it for.Is he a friend of yours? I noticed he calls you out at the end and says "que the music"
Hahahaha. Thats great customer service!Haha. Yeah, I told him in his videos he should put some 70s p*rn music in them, so he said he would, and that was the one he did it for.
As big as you can fit and afford. You can never have enough electrons.How many amps should my next alternator be? And what should my battery cca be? Built Olds 403 motor. 9 or 10:1 compression. Mini torque starter.
