I don’t believe I brought this up, but the following evening after this post I was working on the car, had it running and shut it off.The baseplate screws looked and felt like they were never messed with, so I’m betting it came from the factory like that.
And with the sale price, I’d of been kicking myself up and down the racetrack at the fairgrounds 🤣
I think the holes I drilled are a touch too aggressive, as I have the secondaries completely shut and have the curb idle just barely off of completely shut to keep it idling at 650ish. It’ll stall out of I completely close them.
I’ll have to grab that bracket at some point if I find the bleed holes are a source of a problem. I’ve got an inch tall spacer for the brake booster, and combined with the RPM Air Gap intake, I can fit an allen wrench between the baseplate and intake, but it’s a pain to adjust.
My timing is set at 18 degrees initial, but I need to get a new balancer since the chincy Summit one had the numbers rust, then the whole thing rusted so I only have paint marks for 0 and 18 degrees to go by. Still running ported vacuum, I’ll look in to running straight manifold vacuum over the winter.
And is a single pattern cam with .480 (.512 with 1.6 rockers) lift, 282 degrees of duration 229 at .050 and a 108 degree LSA radical? It’s getting hard to tell with the ludicrous “street” grinds people are running nowadays.
And it diesel’d. Bad. I honestly believe it ran backwards since I needed to crank the r fine over for about 10 seconds before pressure came back up on the gauge.
I don’t think it did any damage (at least it doesn’t sound like it currently) but I’m not confident.
Today I switched from ported to manifold vacuum on the carburetor and the dieseling problem disappeared. I think it’s about 4 degrees more advanced at idle, but I can’t tell due to a dirty timing tab and a balancer that has rust instead of timing numbers. At least that’s one problem fixed.
I’ve also got a vacuum leak, and I suspect it to be my heater control. Used a vacuum tester on it, and even with the selector set to off, I could hear air leaking every time I tried to pull vacuum on it. Even hooked it up to the vacuum connector under the dash, got the same result.
That being said, is there a way to rebuild these vacuum selectors? I’ve got a few spare lying around I can throw at it if they can be, but I don’t know if it’s a torn hose or the whole connector is leaking.
Hopefully I’ll have this thing home next week, I’ve got the temporary garage set up already, but I need to level it:
It ain’t perfect, but it’s better than sitting in the open.
