Monte orlac is right they collapse the same way. If you want real good info on it then go to montecarloss.com and look in the do it yourself section there is a good write up on it. I am going to get one from a Jeep when all this snow melts.
85GPLef41 said:Just make sure the upper joint doesn't have this aluminum end.
The one you need has a steel end and the word "NACAM" stamped on it.
I broke off the plastic piece in the middle also and took off the bolts all the way. If it is seized try hammering it out without bending it. Removing the air cleaner box on the jeep gives you some clearance. The steering wheel can be locked with the bolt facing down so you may have to release the lock and turn the wheel....this happened to me. The bolts are 13mm i believe. My steering shaft wasn't collapsing that much so i soaked it with PB blaster and used a rubber mallet and a block of wood to tap it loose. I also had to file a notch on the steering wheel shaft so the bolt goes in smoothly without galling the threads.I used a round file and took very little off. All for about 15 buck including the wrong one.Hope this helps and here is mine installed. 😀
