Jegs crossmember for El Camino?
Bought this one for mine when I put the T-5 in. Bolts right in 1981 ElCamino
trying to fit this exhaust
26.5”wide with the points you have marked. The “pipe” areas is 7”wx4”H(each) and the transmission mount area is 13”wide area of box tubing. This leaves about a 1” to 1.5 in gap from the floor. If going with 2.5” or 3” pipes should leave enough space if properly installed
wow, thank you so much. I will be under the car tomorrow to check dims while installing a mini-starter.
Pretty sure I'm ordering the Summit crossmember ASAP
will post results/photos
Reactions: Ugly1 and 88AZSS
