Transmissions By Lucille. Had them rebuild the 4L60 that was in the old POS '08 Silverado over two years ago & did a great job. They are in Verona. Used to have a lot shops in the area years back but cat back due to the lack of good transmission guys. For the r&r of the trans, road test/direct delivery to my door they charged $1800 & gave it a two year/24K mile warranty.
DEWA66: Link Situs Dewa Slot Gacor Maxwin Gampang Menang Hari Ini
Dewa66 link situs slot gacor hari ini yang memiliki banyak jenis permainan dewa slot unik dan merupakan salah satu situs slot88 yang gampang menang hingga maxwin.www.transmissionsbylucille.com
Awesome, good to know. Thanks!
Just keep swimming!
That's about all I can do, I just hope someone here is paying close attention because if I drop dead tomorrow they are the only hope for this car ever getting back together!
Worst case James and I both know builders who can work on a 200-4R. I'd be willing to help you source one down here, get it built and ship it to you.
I really appreciate that. When I get to that point if I still can't source once locally, I will take you up on that.
Keep in mind that many reviews are done by people that don't know what they are doing and might have even had someone else do the install that didn't do it right.
Both reviews claim an oil leak , the first one says the pan leaked and replaces the gasket and it still leaks and the second comes back with an update i am betting installer error on both.
UPDATE, The problem I was having with my transmission leaking wasn't a problem with the trans itself, it wasn't installed right the first time and it just took replaced the grommet and that stopped the leak, I couldn't be happier with the trans so far.
Very true. Summit reviews generally don't mean much since basically anyone can write anything.
