yes and no, it is an rpo code, which gm used to specify a particular component based on the car and year. for example, an lt1 eng in 71 is not the same as in 93 or in 2018.
that may be correct for a g body. but his is an A body. in my 79 service manual, the 4speed manual is listed as the m-20 option.
joe
Yes, mine has a factory Tach and has a 2bbl, really a weird car, bare bones other than for some reason It has factory air. Its radio delete crank windows, hell the back door windows dont even open or even have cranks.Does it have a factory tach?
Did the Chevy factory 4 speed come with a 2 barrel?
Thanks for the compliment, It is fun to drive, It does show well but I do have to replace the rusted out hood and was thinking of putting a steel cowl hood on. Gotta fix a little area on the tailgate where there is a dent. The rest of the body seems rust free.Welcome to the site from Houston. That's a cool car. It presents well in the pictures. I'll bet it's fun to drive. Enjoy!
I am hoping it is a factory 4 speed, from what I know, they did make some and I hope mine is one of them. Just hard to verify without a build sheet.Nice wagon, the 4 speed is cool
I dont think its a factory 4 speed, could have been a 3 speed tho
the factory mounted a sheet metal "hump" towards the left side of the tunnel providing shifter clearance, it will be spot welded/seam sealed to the floor, you can either check it from underneath or take out a sill plate, lift the carpet up and feel in there with your hand.
fwiw my wagon was a factory 3 speed, i have long since removed the "hump" and sheet metal'd it over, but my clutch pedal is still in the car
