I have the 395 cam in my truck. It acts like stock as far as powerband, there's just more everywhere.
Yes. I love it! Factory specs plus the cam, intake, carb, headers, and dual exhaust.. she will blow the tires off until you let off.So do you have the L31 installed in the car yet? If so how do you like it? That cam is the same one used in the 383 stroker for Gm and also the cam in the 350 Ram Jet crate motor. You can add the 1.6 rockers with no clearance problem with the valve springs just like GM does on the Ram Jet.
I did not do the 1.6 rockers… thinking I need those?So do you have the L31 installed in the car yet? If so how do you like it? That cam is the same one used in the 383 stroker for Gm and also the cam in the 350 Ram Jet crate motor. You can add the 1.6 rockers with no clearance problem with the valve springs just like GM does on the Ram Jet.
What is your thoughts on the 705 (LT1) camshaft or the 94666492 marine camshaft?I am on here every day just looking and trying to help. These gen.1 vortecs (96=2002) are easy to work with because everything is almost the same as the millions of other small blocks. BUT these have the good heads. And these are in most junk yards and a lot of people have these under their bench. These can be had for $100-$300 cash and carry. Stroker kits from $800-$$$$ reground cams from $140-$200 new hyd roller cams $300+ Power 350-500 for under $1500. if you can do some of the work your self. Or just get a book and read. Its just a simple small block just like the millions that have been out their since 1955.
