leak somewhere
awdblazer
314
81
i got a vacuum pump for coolant system for christmas
i am having some problems
if i pull off the rad cap i can pull it down to -5 and when i turn off the vacuum it slowly goes back to zero
if i pull a vacuum on the upper rad hose removed at the rad i can get -25 ish
if i pull the lower rad hose off i can get maybe -2
do i have a leaky radiator and leaky water pump?
thanks for you help
mccormack944
Mar 31, 2018
58
97
Ohio
Do you think you have a leak or just trying to check for leaks and fill with coolant? You may just not be getting a good seal from the tool to the radiator. The one I have at work will do that and while the air is flowing I have to keep pushing it down and kind of rocking it back and forth before it will seal and shoot up to about 27.5 in on mine.
awdblazer
314
81
Yah I tried that and didn’t work
I guess next step is to buy a new rad cap and put a air fitting and pressurize it to ten ish psi and try to find the leak
I hope it’s not my rad as it’s a copper rad
abbey castro
1,048
1,318
Harker Hts TX
Do you have coolant on the floor? Wamr the car up to operating temp. If you have a leak it will appear magically on the floor. Does the passenger side have the sweet smell of coolant?
UNGN
3,048
3,264
Southlake, TX
Last time I testested a radiator I cut a Mountain bike inner tube and hose clamped it to the inlet outlet and pressurized it. Sucking on a cooling system may unseal things that seal under pressure.
If someone sealed their cooling system with an egg, a vacuum will undo all of the effort and out of the toolbox thinking a previous owner put into it.
