Led in dash cluster
So these are the right ones
My car is a 1980 Malibu... also my grandpa had done the led upgrade on his Monte Carlo 1984 and they worked as well. I forgot Those ones that I originally posted were not as bright as I wanted my cluster.
The ones I ended up going with were 194-whp6.
They are more expensive but if you want bright and white those are the ones I would go with. Keep in mind it might seem like a lot $6.95 per bulb but you will never have to replace them ever again.
The original ones I posted I used for my turn signals, high beam, engine light, batt light Ect... they are brighter than factory still but I wanted a very bright white dash. It's not too bright to stand either
the
Should I keep the factory bulbs for the blinkers ?do the led blink
Yes they blink if they are on a blinking circuit . Benefits of leds are less heat, brighter, longevity and if color is a preference I personally like the look of the white.
What I did was buy the $6.95 ones for the back lighting (6 bulbs) and buy the .99 cent ones for the turn signals, brights, batt, engine Ect that's what I did. I just wanted the least amount of heat and never wanted to tear the dash out again to replace a burnt out bulb that's why I went with all led.
For
beam angle for the 99 cent one which one do I choose 90 or 180?
For
always choose the largest beam angle. That means the light is projected in that direction. Example 90 beam angle will be a more direct beam of light than a 180which will be more of a well rounded light projection
So I should do 180?
