Led in dash cluster
And
I'm tryna order everything at once
I'm pretty sure they are different. I didn't do my glovebox light so I am unsure there. Look under your dash and see what bulbs you have. I know the light under my passenger side dash was an 1156 and I think the one under the drivers side of the dash is a 194 if I remember correctly. If you can tell me what size bulbs you have under yours I can tell you what bulb to order.
Super bright leds is a very good company about returning bulbs that don't work with your application. I've went through a lot of trial and error finding the correct bulb base in millimeter width and length. I had one bulb that was a dud and they sent me a new one right away. Very solid company
I've swapped every single bulb in my Malibu to led. Some work some won't. I purchased some from superbright leds. I didn't buy the dimmable sockets because I wasnt worried about having my dash dimmable... leds use a lot less power and last a lot longer than standard halogen bulbs. Not to mention pretty much 0 heat is given off from the leds
You would have to change the sockets for the bulbs to be dimmable? Or is it for certain bulbs? I've thought about getting leds but have read they are not dimmable.
The ones I bought, which I posted earlier in this thread are supposed to be dimmable.
Thank you guys.
Almost finish just got to get Led for pas side
And under radio
The only problem I had was that I broke my speed gauge stem
Any suggestion of a strong glue
I try to use gorilla glue but it wouldn't hold
And under radio
Also what size led bulb light for glove box
Do I need ? I bought one that that they suggested would fix but it was the wrong size.
